So I put up a thread on selling my current parts. Mainly because the 295x2 does NOT match my build at ALL. It's black case with blue LED fans, blue/black mobo, Dominator Platinum RAM, then the 295x2 just chilling. Does ANYONE know if I can replace the GPU fan with a black one or one with blue LEDs? I think it's just a 90mm but if I measured the fan it looks like a standard fan connector inside the housing so I SHOULD be able to just drop in a new one...right?
https://linustechtips.com/topic/477795-295x2-fan-replacement/
its not a standard fan
https://linustechtips.com/topic/477795-295x2-fan-replacement/#findComment-6401748
