Hello all,
Last night I set my computer off downloading about 4GB of apps from the Mac App Store. When I got up the next morning, it said the download had failed. So I opened Chrome and it couldn't connect to the Internet. Turns out I didn't have a valid IP configuration.
Reboot
Still no valid IP
Reboot into Windows 10
Runs network diagnostics, 'Ethernet' doesn't have a valid IP configuration - Not Fixed
So it seems to be a controller issue because no OS can connect to anything. I can't connect to my local network or the Internet.
Does anyone know what I can do?
EDIT:
For clarification it is a hackintosh not an actual Mac
Failed to load signature. Error 404 - Witty comment not found
https://linustechtips.com/topic/477727-ethernet-controller-not-working-correctly/
What is the specs of Hackintosh? Please follow your topics. @WamWooWam
WamWooWam, on 02 Nov 2015 - 03:40 AM, said:
Hello all,
Reboot
Still no valid IP
EDIT:
Seems like you've got a faulty piece of hardware.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
WamWooWam, on 02 Nov 2015 - 04:55 AM, said:
It's a gigabyte GA-990FXA-UD3 motherboard with onboard Ethernet, should I RMA?
Well, I think that its hardware related.  Especially considering it is happening under 2 OS environments (I am assuming that it isn't a VM and its dual booting).
