Fan for Hyper 212 EVO
nunocv
Hello, so I want to replace my hyper 212 fan, I want a more silent one! What you guys recommend? And should i put 2 (in a push pull) or just 1?
Why did I study Haskell?
you could use the bequite! silent wings 2 but there pretty pricey
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
1 is good enough and i would go with noctuas but if you dont like the look then fractal venturis are pretty good too
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
Scythe Gentle Typhoon
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
Noctua LinusTechTips Edition
So one Noctua NF-F12 PWM good enough? Or the BeQuiet Silent wing 2?
If u dont care about looks of ur pc Noctua
if you do care BeQuiet
But either way those comapnies make great fans
Insert   Dank   Signature   Here.
one is good, there both good fans just choose the one you like the look of better
and a car thread !
Btw, the silent wings 2, PWM or no PWM? And are the beQuiets for static pressure or that doesnt matter?
Silent Wings 2 PWN
StaticPressure vs Airflow does indeed matter
Since its for your CPU cooler you need Static Pressure
Static Pressure is best for moving large volumes of air
Airflow fans move much less air but move more air in a shorter amount of time
Silent Wings 2 PWN
So the silent wings have good static pressure?
Noctua has better
Silent Wings Also good
but noctua is ugly
so i would get silent wings
