Inkjet or laser? (printer)
Refilling laser printers tend to be more expensive than refilling an ink printer.
However, all the laser printers I have used pretty much never need refilling. I have an old HP laser printer, and I think it has been 5 years since I refilled it.
It also depends on what you are going to do with the printers.
Laser printers generally suck at printing colours. So, if you are going to print a lot of photos, I would recommend going with an inkjet printer.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/477142-inkjet-or-laser-printer/#findComment-6393457
*cheap
But as said, it depends, what're you printing? I've personally got a laser printer as I do a lot of documents. Also keep in mind that inkjet ink will dry out if not used regularly.
https://linustechtips.com/topic/477142-inkjet-or-laser-printer/#findComment-6393503
*cheap
99% of the time documents but it happens that I have to print pictures sometimes.
https://linustechtips.com/topic/477142-inkjet-or-laser-printer/#findComment-6393508
