Need help with LED capacitive dropper math
I have some 230V leds from an Ebay listing, the seller's listing said 120v. The seller was a US supplier. Anyway, They use a capacitive dropper circuit. The mains comes in, through two paralleled 330nf capacitors with a 1megaohm resistor in parallel with the caps, then into a bridge rectifier. The output of the diode bridge goes into two series strings of 54 LEDs, and each string has a 100ohm resistor in series with it. What value of capacitor should I use to make them work on 120v, driving each LED at 15-20mA? I suck at complex math.
https://linustechtips.com/topic/476972-need-help-with-led-capacitive-dropper-math/
I believe this the the formula for it I'm not very well versed in this stuff and the technicalities so I would double check:
http://www.edn.com/design/power-management/4418393/AC-power-your-circuit-without-a-transformer
seee? I literally just woke up and checked ltt.
here you are again. btw I'm supposed to know all these stuff considering the electives I took in HighSchool we're all electronics sadly I can't remember shit now.
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
I'm not sure how your are wired up but this shows both 240v and 120v for converting old school bulb lights to led using a very very simple circuit with some resistors and a bridge rectifier.
@3:00
-https://www.youtube.com/watch?v=zopCnL3LS-s-
@3:00
OOH More bigclive! here is the schematic of the bulbs I have:
Clive and I are actually discussing it right now.
"Resistance" of the capasitors (Xc): 1/(2*pi*f*c) = 1/(2*pi*50*660nF) = 4.82kOhm
100 Ohms in series: total resistance = sqrt(Xc^2+R^2) = 4.82kOhm
Assumption: 2.8 volts per LED -> one string = 151.2 volts
Average current at 220 volt: (220-151.2)/4.8kOhm = 14.26mA -> seams reasonable.
You can runn the LED without the capasitors at 120 volts but they won't be as brigth as on 220 volts. The voltage is to low for 54 LEDs in series.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
