I recently replaced my ASUS motherboard with a MSI Z97 Gaming 3 as the Asus motherboard pretty much died. On the ASUS motherboard, my 4770K was running on 4.4GHz pretty fine and after I switched over to the MSI I started to run up to some problems. Whenever I try to overclock my CPU to 4.4/4.5 GHz the temps are going to 100 degrees's right away when I stress test it with Prime95. Now I'm actually curious if it's my H80i that's not cooling properly, if my 4770K is about to die or if there is a option in the BIOS that add's more core voltages as i set in BIOS.
https://linustechtips.com/topic/475951-adviceshigh-temps-overlocking/
Don't use p95 first of all. It overvolts.
Second, remount your cooler.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
It could be both the CPU and the H80i, as that probably killed your last mobo. DO a check in the settings and such in the advanced menu of your bios.
Prime95 burns your CPU to death!
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
I would use Adia64, P95 murders cpus
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
What did you set the voltage at? Pre-Devil's Canyon Haswells are notorious for having terrible TIM between the die and IHS. Even if you set the voltage at something reasonable, the only fix may be delidding.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
I installed my motherboard 2 weeks ago even put new cooling pasta on it, yesterday i remounted the cooler on the CPU and replaced the cooling paste once again.
My Asus motherboard was already causing problems before i overclocked it. It's a second hand PC that i bought 1 year ago and the motherboard was doing weird all the time so it's not possible that the CPU killed the motherboard.
I will try Aida64 and come back with some results.
Hereby the voltages and pics.
Core voltage: 1.190v (not sure if this is really high for 4.3Ghz overclock, i had to go up that high as Prime95 gave me BSOD, not sure if this is caused by Prime95 as some of you guys said)
http://i66.tinypic.com/23uvkfb.jpg
http://i68.tinypic.com/30igvid.jpg
Cooling pasta.
I overclocked the CPU to 4.5GHz on core voltage of 1.240v. I ran Aida64 for 5 minutes to see what temp I would get with this configuration and if it would BSOD.
The temps went really high as you can see on the screenshot, but it was mostly staying between 85-92 which seem pretty high for me. I would expect that the 4770k would be much cooler especially after reading Anandtech's(http://www.anandtech.com/show/8227/devils-canyon-review-intel-core-i7-4790k-and-i5-4690k/2) article with their results @ 4.5Ghz cooled with H80i. Should I consider replacing my H80i with H100i / Noctua NH-D15? Or replacing the CPU with 4790K?
Update:
I got BSOD after i re-opened my chrome (with 7 tabs saved) and increased the core voltage to v1.250 , below are the results of 5 minute run.
bump
Never use PRIME!!!
I already removed Prime, replaced it with AIDA64. See the AIDA64 stress test results above.
Check thermal paste and make sure voltage is not to high...
I already replaced it.
How much?
Just a little bit in the middle of the CPU, like a dot.
Geeh you sure your cooler is working?
Yes, the fan on the H80i is working, also the 2 pipes from the H80i whenever i touch it on 100% CPU load.
What RPM is the pump running at?
What are your temps, before you OC it? If it still runs toasty at stock speeds... then somethin might be wrong with your cooler. Just a guess
Fire Tail: CPU - Intel 7700k. MOBO - MSI M5 Gaming Z270
RAM - G.Skill RipJaws V 2x8GB (16GB). GPU - MSI 1070 Gaming X
____________________________________________________________________________
Editing Rig: CPU - AMD Ryzen 3900x with NZTX Krackenx240. MOBO - MSI ACE MEG Z570
RAM - G.Skill Trident Z 32GB (16GBx2) 3200hz. GPU - MSI Gaming Trio 2070 Super
So does OCCT, Aida 64 and other things as well.
It only does it when adaptive voltage is on.
2406 - 2432 ish RPM idle and 100% CPU load, I'm not even sure if the RPM's are displayed correctly, though.
HWMonitor screenshot: http://prntscr.com/8ynee9
I haven't run it on stock speed, i will do that and do a another run with AIDA64 and post the results whenever i got time.
A small update. On AIDA64 I noticed CPU and FPU were both selected when I done the previous stress tests, my CPU is currently clocked on 4.3GHz at v1.190 core voltage. Here are the new temps without having FPU enabled:
Comparing this results with the previous one, there is around 15/20-celsius difference. I will try to overclock it to 4.5GHz 1.25v
