Running Folding@Home off a flash drive?
First off - it is not allowed by Pande or Stanford to run the Folding client on any system which you are not the sole owner of or have direct permission to use.
Second, I have seen people try this, for large groups of systems, and you basically need to install locally on every system. After that, you can use something liek Group Policy or such for pushing out new config files...
Your school also has an acceptable use policy which most assurdely only allows the use of authorized software. So, you would need written permission to do this. Esp as you will increase the heat the systems produce and electrivity they use. They will notice their power bill going esp, more so if the AC is needed more as well.
FYI - I know of direct cases where someone has been fired for doing this on work systems without permission and where someone has been expelled from school, again for trying this without permission. Do not do it unless you get written permission from whomever manages the IT for the school also indicating that your are Folding and heat and electricity use will be a direct cause.
