It suddenly turns off
Then motherboard shows that psu is giving power
Nothing else has light
Then later it automatically turns on for no reason
Each time it turns off the off time increases
It wont even say shutting down
Instant black out
Im freaking out guys.. please help
Rm1000i
R9 390
5820k krait x99
Noctis 450
16gb geil ram
240gb ssd
Windows 10
Jus happened today have been using for 2 weeks
“It would seem that Our Lord finds our desires not too strong, but too weak. We are half-hearted creatures, fooling about with drink and sex and ambition when infinite joy is offered us, like an ignorant child who wants to go on making mud pies in a slum because he cannot imagine what is meant by the offer of a holiday at the sea. We are far too easily pleased.”
―  C.S. Lewis  :)
https://linustechtips.com/topic/475762-my-pc-has-issues/
Maybe your PSU is not supplying enough power, not sure though
[CPU] i5-650 [GPU] MSI GTX 750 OC [RAM] Generic 6GB [MOBO] MS-7613 [HDD] WD Blue 1TB [PSU] Silverstone Strider Essential 500W [Next build Q1 2016 http://de.pcpartpicker.com/user/Presmo/saved/ ]
Please follow your own topics.
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375497
The cables are unstable?
That as in Maybe the cables connecting to your hdd or gpu etc. are unstable. Try redoing the cables and whats your psu?
Specs: i7-4790k with Thermaltake Water 3.0, EVGA GTX 970, MSI Z97 Gaming 3, Kingston HyperX 2x8 DDR3 1600Mhz, SSD Boot Drive/1TB HD, CM Storm Stryker, EVGA Supernova G2 750W
Peripherals: SS Rival, HyperX Cloud, G710+
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375506
Check all the cables that they are plugged in all the way
CPU - i5-8400 , Motherboard - ASROCK Z370 Killer SLI, RAM - 2x8 GB DDR4 2400mhz , GPU - EVGA GTX 950 SC, Case - SilentiumPC PAX M70 Pure Black V2 Storage - 240GB SanDisk SSD, 1TB WD Blue, PSU - bequite! 600w Pure Power 10, Display - Dell P2417H, Cooling - bequiet! Pure Rock, Keyboard - Viper V730, Mouse - natec Genesis G55, Sound - Philips MCD712, OS - Windows 10 Professional 64-bit
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375518
Several possibilities. None of which you are going to like.
  1. The Cables for the power supply are not connected fully
  2. The power supply, for some reason is failing. -Generally though, you'd get a BSOD-
  3. The motherboard is dying on you.
  4. The graphics card is dead/dying. -You would get crazy mad artifacting when it DOES boot.
In order of most likely, to least likely from my point of view.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375530
look at windows event viewer
it tells you why
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375578
Test it only with Mobo, CPU , HDD and RAM
Are you using modified cables(you know ,custom sleeved)
No but i did have a super hard time wiring
―  C.S. Lewis  :)
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375697
it tells you why
Its hard to use lol
―  C.S. Lewis  :)
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375709
it tells you why
This time it happened after i accidently touch it
It should be loose wire i think
―  C.S. Lewis  :)
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6375818
check that your ram is in the slots 100%
when you put it in you should not touch the clips
just press down until the clips close themselves
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6376004
Did it, just to ask, am i able to plug the power cable into (idk what its called....)
It basically extends and from 1 plug becomrs 4 plug
―  C.S. Lewis  :)
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6380796
yeah
https://linustechtips.com/topic/475762-my-pc-has-issues/#findComment-6381589
