anyone have suggestion for cnc machine. just need to mill aluminum and wood. i have heard the xcarve is good. is there anything better? does anyone have the xcarve?
thanks
maybach123
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/475482-best-cnc-machine/
Cnc machine is mainly just a controller with rails. There is little to know difference in all of them apart size user friendly software. The difference is in the router and the drill bit quality
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/475482-best-cnc-machine/#findComment-6371640
"Cnc machine is mainly just a controller with rails"..... just wow.... CNC just stand for computer numeric control there are hundreds of different type of CNC machines and you just offended them all! =p also not all cnc machines have rails... silly noob =p
https://linustechtips.com/topic/475482-best-cnc-machine/#findComment-6371666
as someone who works with cnc's daily, i can tell you you couldn't be any more wrong.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/475482-best-cnc-machine/#findComment-6371778
+1 to that!  Although I appreciate how the hobbyist cnc router type machines are starting a new trend in the home machining/maker world, I'll stick with my 20hp Haas VF-3SS for now...
To the OP, something like the X-Carve is great if you're willing to invest the money but it's limited in it's abilities especially when you get into metals.
https://linustechtips.com/topic/475482-best-cnc-machine/#findComment-6372811
i know but i have a machine shop down the road that can pretty much machine any metal for little cost (as long as i provide material) so when it comes to metals im kinda set
https://linustechtips.com/topic/475482-best-cnc-machine/#findComment-6374994
