LED Lighting - Case and Desk
Go to solution Solved by Guest,
Oh okay so it's like a central like control box that comes with LED strips then?
yeah, you can do cool things with it
you can sync it up to music, FPS ect
NZXT's professional staff play around with it at around 8 ish minutes
http://www.twitch.tv/nzxt/v/22774068
Hi, so I recently bought a new glass desk for my work/pc/office area and I was wondering if there was something I could use for lighting up these areas. I have seen these types of area being lit up before, but I can not recall what was available for solutions to these types of areas. I believe I have even seen RGB lighting in these areas but I'm not sure what was used. In addition, anything for lighting up a PC case as well? Any ideas or recommendations?
https://linustechtips.com/topic/475409-led-lighting-case-and-desk/
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
Kits like theses RGB LED strips are your best bet for doing ambient or area lighting:
http://www.amazon.com/SUPERNIGHT%C2%AE-Waterproof-Flexible-strip-Changing/dp/B00ASHQQKI/ref=sr_1_11?ie=UTF8&qid=1446077188&sr=8-11&
https://www.nzxt.com/product/detail/163-hue-plus-case-accessory.html
This is what I recommend, the software is extremely well coded NZXT is just waiting for the actual units to arrive. It fits in a SSD mount, the strips have magnets on them so, go figure you can put them anywhere. You can do a lot of cool things with it.
Edit: comes with 4 LED strips included, a max of 8 can be used per device (I'm assuming you can have multiple) but 2 LED strips will light up a whole S340
Will this work for a PC case as well?
Yes they will. You can pick one with a Molex connector and plug it into your power supply. Some even connect off fan headers.
I don't think I understand what the box is lol
Fucking sweet, thanks!
Anything else similar to this that is on the market right now?
