So i resently bought a bm800 condenser microphone and it needs phantom power, but one review said that if you have a desktop with 500w + then you can run it strait of that
right now i am running it into my 3.5mm mic jack directly from my mic and it is rather quite
can i run it of my 550w psu , do i need to get a phantom power supply (which i cant really afford) and can i get an xlr to usb 3.0 to run it without phantom power
https://linustechtips.com/topic/475344-microphone-power-help/
thats not how it works
at all
you need to feed the mic 48v
what power supply your PC has doesnt matter, because a 3.5mm jack does not send 48v
you need an audio interface
https://linustechtips.com/topic/475344-microphone-power-help/#findComment-6369904
well do you have any recommendations
http://origin.behringer.com/EN/Category/Computer-Audio.aspx?s=N100
just check the specs to make sure they it has phantom power
https://linustechtips.com/topic/475344-microphone-power-help/#findComment-6369940
