GFX Card Adapters for Laptops
My current notebook (Asus A55VD) has a GTX 610M in it and it runs games decently. However I would like to have a better visual experience and I cam across an external adapter for laptops. However it connects via ExpressCard, I do not have one of these ports on my laptop. But I do have an open HDMI and Serial port. Would getting an adapter for one of these ports to the the ExpressCard work, which one, and how much would it impact the performance?
no that wouldn't work, the serial bus is way too slow and I doubt that's an HDMI in port.  ExpressCard docks are very buggy regardless from what I've heard (assuming you're referring to ViDock EGPU solution)  You need thunderbolt (like on MacBooks) or one of alienware's laptops with the GPU port if you want to run external graphics
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
There is no interface for laptops that can drive speeds greater than something like PCIE-e x1.  Those adapters are worthless.
Workstation:  14700nonK || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3060 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
My laptop does actually have a HDMI slot on the left. And the ExpressCard is actually a piece that comes with the set I found that coverts the PCI-e to the ExpressCard. This piece could be eliminated if I could go from the PCI-e to the HDMI. Would the HDMI work?
I have an Asus A55VD which is decent at gaming. However I want a better visual and performance experience. Instead of getting a PC or a new laptop I was wondering if I could set up a GFX Card externally? Could someone please help me sort through this.
follow topic.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
no HDMI is not a system bus signal.  Expresscard (although incredibly slow) is a system bus signal, so theoretically you could run a GPU on it like ViDOCK wants you to do, but you would probably suffer extreme bottlenecking.
tl;dr I doesn't work with your laptop
