Yes it does, go for it!
Edit: Try getting a 650W PSU, just to be safe.
https://linustechtips.com/topic/47388-two-way-sli-help/#findComment-628232
I would suggest getting bigger psu (some high end 650w-750w) should be plenty.
Intel i5 3570k | MSI GTX 670 Power Edition/OC SLI | Asus Sabertooth Z77 | Corsair Vengeance LP 16GB | Fractal Design Newton R2 650W | NZXT Switch 810 SE Gun Metal | BenQ 24" XL2420T 120Hz | Corsair K90  | Logitech G500 / Logtitech Performance MX | Sennheiser PC 360 | Asus Xonar DGX | NVIDIA GeForce 3D Vision 2 Wireless Kit
https://linustechtips.com/topic/47388-two-way-sli-help/#findComment-628251
It works fine. Stated already, a 650w would be a bit better.
I'd recommend getting a better sdd: http://uk.pcpartpicker.com/part/kingston-internal-hard-drive-sv300s37a120g
https://linustechtips.com/topic/47388-two-way-sli-help/#findComment-628320
This!
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/47388-two-way-sli-help/#findComment-628347
