Does you internet work when you go back to stock?
https://linustechtips.com/topic/47377-problem-with-over-clocking/#findComment-628119
This doesn't really belong in the guides and tutorials section, try posting it in the other sections, you will probably get more help.
CPU: AMD FX-8350 | CPU Cooler: H80i | Motherboard: Asus M5A99FX PRO R2.0 | RAM: 8GB Kingston Beast 1866MHz
Case: Define R4 | GPU: Gigabyte GTX 780ti | PSU: Corsair CX600M | SSD: 250GB Samsung 840 EVO
.... and a Partridge in a pear tree!
https://linustechtips.com/topic/47377-problem-with-over-clocking/#findComment-628133
what settings did you touch when dialing in your OC?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/47377-problem-with-over-clocking/#findComment-628476
try it with a more gentle oc and see if it works, my only idea is that it might be a lack of power, what PSU do you have?
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
https://linustechtips.com/topic/47377-problem-with-over-clocking/#findComment-628816
@Hirad123 bus frequency: 250, ratio: 16
so you are overclocking over BCLK rather than multiplier? I wouldn't recommend doing it that way cause that can effect your other hardware as well. Try changing your ratio to 40 and leaving your bus at 100
https://linustechtips.com/topic/47377-problem-with-over-clocking/#findComment-633048
