i5-4690K for sure.
You don't even know what his use scenario is. How can you recommend a CPU then?
Hi im a long time fan of linus tech tips but just created an account in their forums can you guys help me build my rig i have a 1500 canadian dollars budget...what parts should i get with my budget??thank you in advance
We can help you pick the parts for your system, but you've to build it yourself obviously.
If you want us to pick parts for your system, we need to know what exactly you want to do with the system, if you need a monitor, mouse and keyboard and if aesthetics are important to you. If they're important to you, we need to know which case size and colors you prefer.
You don't even know what his use scenario is. How can you recommend a CPU then?We can help you pick the parts for your system, but you've to build it yourself obviously.If you want us to pick parts for your system, we need to know what exactly you want to do with the system, if you need a monitor, mouse and keyboard and if aesthetics are important to you. If they're important to you, we need to know which case size and colors you prefer.
for gaming and occasional video editing,i need everything and aesthetics is not that important and interms of color black in orange would be nice
k, shouldn't be too much of a problem to build that. I have already an idea. I forgot to ask in which country you live. :P
philippines so i converted my budget to canadian :D
I'm done. I landed exactly on 1500,62 :P
There is a problem tho. Because you're living on the Philippines the prices can fluctuate a lot. You might be able to get better hardware in your country or the budget might not be enough to buy all of the parts, so you'll have to check prices yourself.
I've gone with an Xeon, simply because it supports hyper-threading, which will help you in multi-threaded tasks like video editing.
It's single core performance is not quite as good as an i5-4690k, but you could simply get an i5 if you want to. Then you might have to chnage the motherboard with a Z97 one.
But overall I'm really happy with the choice of parts. It's perfect for 1080p gaming, great for video editing and also will look really great. The Fractal case will also help a lot with noise. You shouldn't be able to hear that thing at all.
The PSU is modular, so that'll help you building the rig.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($331.38 @ shopRBC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($36.99 @ DirectCanada)
Motherboard: ASRock Fatal1ty H97 Killer ATX LGA1150 Motherboard ($175.00 @ Vuugo)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory ($105.97 @ DirectCanada)
Storage: Crucial BX100 250GB 2.5" Solid State Drive ($109.99 @ NCIX)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($86.33 @ Vuugo)
Video Card: MSI Radeon R9 390 8GB Video Card ($439.98 @ NCIX)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case ($134.99 @ NCIX)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($79.99 @ Newegg Canada)
Total: $1500.62
Generated by PCPartPicker 2015-10-25 09:20 EDT-0400
