You're getting sound from everything else?
Not much information, all I can suggest is to check sound options in-game but you've probably done that.
On Pc. No Stem. Windows. i am getting sound on everything else
"In the middle of every difficulty lies opportunity."
- Albert Einstein
https://linustechtips.com/topic/473091-no-sound/#findComment-6341428
Are you running as administrator?
What are your specs?
What version of windows are you using?
Are you drivers up to date?
Are the volume settings for the games on?
Are the games able to detect your graphics drivers?
Have you checked if they have any output in volume mixer?
https://linustechtips.com/topic/473091-no-sound/#findComment-6341433
1) No
2) http://linustechtips.com/main/topic/469434-the-titanium-beast/#entry6295409
3) Windows 10
4) Yes, if you mean by gpu.
5) Every single one
6) They dont have any output
- Albert Einstein
https://linustechtips.com/topic/473091-no-sound/#findComment-6341445
Try reinstalling the games.  I had an issue last week where it wouldn't run and it though my HDD had bad sectors.  Turns out the game has been buggy since last week.  That's black ops 2.
I had already done that
- Albert Einstein
https://linustechtips.com/topic/473091-no-sound/#findComment-6341489
So, what have you done so far?  JW
All My Drivers are Up to date. I have Dx 12, I have everything this is the cracked version. I want to test put the game before i buy it.
- Albert Einstein
https://linustechtips.com/topic/473091-no-sound/#findComment-6341509
The SP and MP is fun, but Black Ops 1 is loaded with modders and black ops 2 is starting to get that problem.  The SP is worth it though.
See my brother bought bo2 he got VAC Banned and he did not hack. I literlly watched him play the game, and never use mods.
- Albert Einstein
https://linustechtips.com/topic/473091-no-sound/#findComment-6341675
Black Ops 1 only play for SP imo, but on Blacks Ops 2 has a lot of team players over modders.  So, you'd be fine playing black ops 2 without heavy modders.
anyways I only play 1 v 1s andn never go online.
- Albert Einstein
https://linustechtips.com/topic/473091-no-sound/#findComment-6341705
I was playing online the other night, and I guy has 22-0.  Which is very suspicious.  Even with gun add-ons the one that lets you shoot through walls had limitations..  This guy was using a mod that lets you shoot through everything, and was spamming the crap out of killstreaks.  <<
Anyways, that is why the cracked version appealed to me
- Albert Einstein
https://linustechtips.com/topic/473091-no-sound/#findComment-6341730
