this is the best i can do video wise http://tinypic.com/r/nozvvd/8
My Corsair H55 Pump is making a weird clicking noise while playing GTA 5 and my PC also has a burning smell??
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
https://linustechtips.com/topic/472731-pump-making-weird-noise/
Clicking noises means a faulty pump. It's normally caused by running the pump dry but it not the only reason.
Burning smell is not good no matter what causes it. You need to put your nose into your computer and give it a good sniff to find out what's causing it. Get right in there.
It's not a race to the bottom.
https://linustechtips.com/topic/472731-pump-making-weird-noise/#findComment-6337401
