CPU power connections
Go to solution Solved by Tedster,
Im building ancomputer for my grandpa and i need to know if i can use 4 connections of the 8 pin header to power the cpu safely, because thats the only connection the psu has
Are you sure that the PSU doesn't have two separate 4+4 connectors somewhere?
Sig under construction.
https://linustechtips.com/topic/471763-cpu-power-connections/#findComment-6325253
yes i am sure
Just use one side of the connector. and make sure the shapes of the pins line up correctly (The plastic shape).
Cheers!
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/471763-cpu-power-connections/#findComment-6325273
my bad :P the connector slid apart into two fours
*Round of applause* Enjoy the build!! Just don't forget to plug the HDMI cable into the USB port for the first boot. That's how you get to the advanced BIOS. ;P
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/471763-cpu-power-connections/#findComment-6325282
thats why its called 4+4pin power :)
https://linustechtips.com/topic/471763-cpu-power-connections/#findComment-6325296
