thanks unfortunately the color of the noctua isnt red xD
The Noctua Redux fans are grey. However, the NF-S12 will be no good for radiators, so if you've got 140mm rads, get the NF-P14. Otherwise, ignore me.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/471523-which-fan-is-better/#findComment-6322439
If those are the only two options, go for the Corsair fans, and buy some earplugs while you're at it...
what do you think about the sp 120 the red led version
Ah, that changes things... If red LED fans are also fine, consider buying them off Phanteks or Cooler Master. They're going to be just as good as Corsair's fans, but much, much, much, much, much quieter.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/471523-which-fan-is-better/#findComment-6325603
Cougar Dual X or Thermaltake Riing?
kindly check the specs and recommend me whats is better for radiator and case fan
http://www.cougargaming.com/products/fans/cfd_red_led_fan/(kindly click specification)
http://www.thermaltake.com/Cooler/Case_Fan_/Riing/C_00002634/Riing_14_LED_Blue/Specification.htm
https://linustechtips.com/topic/471523-which-fan-is-better/#findComment-6329554
I'd say the thermal take one but if you can afford it get Noctua fans they are some of the best.
https://linustechtips.com/topic/471523-which-fan-is-better/#findComment-6329562
If specs are true, then the Cougar fan all the way and every day.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/471523-which-fan-is-better/#findComment-6329666
I tried them both and they are both terrible.
The Riing moves almost no air and is super loud at 7 and 12V. The pressure is pretty good tho.
The Cougar CFD are also really loud at 7V and 12V, but these move at least quite a lot of air. I have no idea about their air pressure tho, but I think it shouldn't be too bad.
I recommend to get some high quality fans like be Quiet Silent Wings or Noctua fans.
If you want lighting in your case you should use LED strips.
https://linustechtips.com/topic/471523-which-fan-is-better/#findComment-6329941
