Overclocking 6300 problems
Solved by Enderman,
as i said, i could use all the help i can get, im fairly new with overclocking
https://www.youtube.com/results?search_query=amd+overclocking+guide
you need to increase the voltage by small increments until it becomes stable while remaining below the maximum temperature
basically go watch a bunch of videos and learn how to do it properly or you're probably going to ruin something
