Need a replacement for my current SSD running windows 10
Solved by typographie,
Your license ties itself to "your system" (probably meaning the motherboard) but should continue to work after only an SSD swap. Windows 10 seems to activate itself automatically via Microsoft's servers, so don't be surprised if it "just works" without prompting you for your key.
The Windows software is freely available from Microsoft's website. You'll need to set up a USB flash drive or DVD yourself, though.
