Good CPU Cooler for a Mid-Tower
PlamenDrop
Hello,
I am looking for a good air cooler to fit inside my NZXT S340 case that can support 2 sticks of high profile RAM. Does anyone have any suggestions?
I am running a 4790K on an ASRock Z97 Extreme4. Not planning on overclocking right now, but I'll invest in a water cooler if I ever decide to OC in the future. I'd prefer something around $50. I was checking out the Hyper 212 Evo, but I doubt that'll fit in the case...
Thanks!
The Noctua U12S sells for 60usd in my country. It has to be cheaper over there :) !
Get the Noctua U14S if you want to have better overclocking yields on an air cooler. The U12S can already cool well though
i5 4670k | Noctua NH0-U12S | Asus Z97M Plus | Kingston HyperX Fury 8gb | Palit GTX 980 Ti Super Jetstream 6G | Samsung 850 EVO 250gb
WD Caviar Blue 1tb | Seasonic M12II 850W | Fractal Design Define R5 | Dell U3014 1600p 30" 60Hz
Corsair K65 | Razer Orochi | Bose QuietComfort 15 | Creative SBS A350 2.1
Main ||  i7-4790K @ 4.4GHz || Corsair H90 || Gigabyte GA-Z97X-UD3H-BK || HyperX Fury 16GB || Samsung 840 EVO 500GB || WD Green 4TB || EVGA GTX 750 Ti FTW || Fractal Core 3500 || Corsair CX 500M ||
Wiseplex || i7-4790 @ 3.6GHz || Corsair H50 || Gigabyte GA-Z97N-WIFI || HyperX Fury 16GB || Samsung 840 EVO 250GB || WD Green 6TB || EVGA GTX 750 Ti SC || Fractal Node 605 || Corsair CSM 450 ||
Tell us what case you have and we can figure out what clearance you have for the CPU height.
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
Hello,
Thanks!
http://pcpartpicker.com/part/cryorig-cpu-cooler-h5universal
http://pcpartpicker.com/part/cryorig-cpu-cooler-h7
http://pcpartpicker.com/part/phanteks-cpu-cooler-phtc12dx
AIO Watercooler
http://pcpartpicker.com/part/cooler-master-cpu-cooler-rls12v24pkr1
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
GAMING RIG:
CPU: Ryzen 5 5800X3D
MOBO: ASUS TUF Gaming X570 PLUS (Wi-Fi)
RAM: 32GB G.Skill Ripjaws @ 3600MHz
GPU: PowerColor Fighter RX 6700 XT
STORAGE: 500GB Crucial MX500 M.2 (Boot Drive) / 500GB Crucial SATA / 1TB WD HDD
CASE: Dimas Tech EasyBench V3.0
VR RIG:
CPU: Ryzen 7 5700x
MOBO: MSI B550 Gaming GEN3
GPU: Zotac AMP! 2080 Super
STORAGE: 250GB ADATA SSD / 500GB WD Blue SSD / 1TB WD Blue HD
I specified that in my original post.
Why not stick with the stock cooler if you don't plan to oc yet?
It's not the most attractive pieces of hardware...
The Pure Rock is good for a moderate oc: http://pcpartpicker.com/part/be-quiet-cpu-cooler-bk009
If you would like to push for higher oc's, the True Spirit 140 is a good alternative: http://pcpartpicker.com/part/thermalright-cpu-cooler-truespirit140power
I just got the rig up and running. I decided to leave the stock cooler in until I can get a good holiday deal on a decent cooler. As soon as I fired up the PC, the sound of the stock cooler was utterly terrible! I don't know if I can last until Black Friday...
Have you tried adjusting fan settings in the bios?
I'll just leave it on default settings for now to see if I get used to it, otherwise I'll switch to silent mode.
