A friend of mine has asked me to build him a PC to play games and also use either Fraps or Dxtory to capture the game. The two CPUs that I considered for the build were the i7 3770 or the FX-8350. The FX-8350 is cheaper and allows me to fit an SSD into the budget. Would any of you recommend one of these CPUs or something different? I understand that the FX-8350 will allow overclocking which will allow me to get extra performance from the CPU.
Specs for the build are:
Corsair 300r
CXM 600 (Possibly TX650)
2Tb Seagate barracuda
8GB RAM
XFX 7870 Tahiti LE
SanDisk 128GB SSD (If using FX-8350)
AMD FX-8350
Asus M5A97 LE R2.0
Or
i7 3770
MSI H77MA-G43
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/
FX 8350 or 3770
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622588
The 3770 will likely outperform the 8350 in most games.
Don't be so sure.
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622605
An SSD is quite nice to have. Although the 3770 will likely outperform the 8350 in most games, it isn't enough to skimp on getting a faster hard drive.
Outperform? I thought games didn't stress CPU enough to make a noticeable/constant difference between i5, i7, 8350, etc.
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622610
Check out the Intel vs AMD video on this topic:
http://linustechtips.com/main/topic/46978-for-best-z87-gd65-motherboards-performance/
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622622
FX 8350 known as best cpu for gaming
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622623
There are definitely games that stress the CPU enough to make a difference, but even in the most extreme cases it may only be a 6~ frame difference. The difference between an i5 and an i7 in gaming isn't relevant, but an 8350 vs a 3770, there will be a difference in some games. There are also some games where the 8350 actually wins as well, but from the benchmarks I've seen, it tends to be less frequent.
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622630
8350, with the new consoles having an 8 core cpu, the games will be optimized for that
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622659
How about neither ? I have a better proposition, the FX 8320, it's $40 less expensive than the 8350 but overclocks nearly as well as the 8350.
The $40 in savings will allow you buy a very good aftermarket cooler for the CPU and really take advantage of its overclocking potential.
The NZXT Havik 140mm CPU cooler is what I'd recommend it's only within a degree of the Noctua NH-D14 and the Corsair H80 (any double thickness liquid cooler) but it's less expensive.
The Asus M5A97 R2.0 is a perfect board for the job and it's what I'd recommend.
Also please take note that the HD 7950 has come down in price significantly, making it a much better choice than the 7870 Tahiti LE.
The blue text links to Amazon.com webpages of the product.
I hope this helps.
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622683
Corsair 300r
8GB RAM
XFX 7870 Tahiti LE
AMD FX-8350
Asus M5A97 LE R2.0
Or
i7 3770
MSI H77MA-G43
Get the 8320 but jump up to the M5a99x Evo R2.0
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-622760
Get the 8350, the ssd will make a big difference.
CPU: I7 3770k @4.8 ghz | GPU: GTX 1080 FE SLI | RAM: 16gb (2x8gb) gskill sniper 1866mhz | Mobo: Asus P8Z77-V LK | PSU: Rosewill Hive 1000W | Case: Corsair 750D | Cooler:Corsair H110| Boot: 2X Kingston v300 120GB RAID 0 | Storage: 1 WD 1tb green | 2 3TB seagate Barracuda|
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-623124
i'm using a 6100, which is just a 6 core version of the 8 core you're suggesting.
i have to say, amd chips run hotter and carry more power. from my experience, 3770k, and get him to borrow money for a ssd. he wont regret it
hope this helps
Gaming/Engineering PC: -i7 6700K, 4-4.2GHz "Eleanor" -ASUS ROG HERO VIII MOBO -16GB DDR4 3000MHz Corsair (2x8GB) -Gigabyte Windforce 980Ti OC edition (1405MHz GPU clock) -H110i GT Corsair CPU Water cooler -980GB Sandisk Ultra II SSD -Corsair 450D ATX Case -RM850i Corsair PSU (Modular) -28” 4K Samsung -27” 1080p Samsung
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-623145
I got the AMD FX-8320 on Thursday for £30 less, I'd definitely recommend going with it over the 8350, I've been able to get it to 4.6 on stock (1.35V)
CPU: Intel Core i7-4790k @ 4.7 1.3v  with a Corsair H80 w/Dual SP120s - Motherboard: MSI Z97 gaming 5 - RAM: 4x4 G.Skill Ripjaws X @ 1600 - GPU: Dual PowerColour R9 290- SSD: Samsung NVME SM951 256GB-- PSU: Corsair RM 1000  - Case: NZXT H440 Black/red - Keyboard: Coolermaster CM storm Quickfire TK, Cherry MX blues - Mouse: Logitech G502 - Heaphones: Beyerdynamic DT 770 - Monitors: 3x VE248H Eyefinity 1080P -  Phone: iPhone 6S Plus               Please post your specifications in your post, signature or even better, system page on your profile!
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-623203
FX 8350 or 3770
If your budget is limited, the FX-8350 will be better with an SSD. Get a decent motherboard to have the overclocking potential you will need it in the future.
CPU: Ryzen 7-3700x 4.4GHz, MB: ASUS PRIME B450M-AGPU: SAPPHIRE RX 590, RAM: 16GB Corsair 3200MHz, SSD: 480GB Kingston HDD: 2TB WD Green, CHASSIS: CoolerMaster HAF 912, PSU: CoolerMaster Thunder 700W, COOLERHyper 212 Black Edition
https://linustechtips.com/topic/47016-need-help-choosing-a-cpu/#findComment-623422
