gpu stuck at 550mhz
Go to solution Solved by Curufinwe_wins,
You crashed and it went into safe mode. Restart your computer with the overclock disabled and it will work again.
If that fails you will need to uninstall and reinstall drivers.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/469980-gpu-stuck-at-550mhz/#findComment-6302309
I had a similar problem on my GTX 760... the card would frequently get stuck at idle clock speed when playing Smite or GTA V so I ended up playing at like 20-30 FPS :/
Eventually it just went away, none of the immediate solutions I tried fixed it. Reinstalling the drivers didn't fix it for me, goofing around with the settings didn't change anything... not sure why it stopped happening.
https://linustechtips.com/topic/469980-gpu-stuck-at-550mhz/#findComment-6302322
