Hello, this is going to be my first gaming PC build. I have games like DayZ, Arma (2 and 3) and CS:GO that I can hardly play due to poor fps. Therefore, I am looking for a PC that will give me good performance on Arma and DayZ as CS:GO is easy to run (obviously).
My build: http://uk.pcpartpicker.com/user/xMatty/saved/#view=PTjD4D
I have just got a few questions about the build.
Is it all compatible?
Is it worth the money?
What FPS would I be expecting on the games I mentioned before?
Thanks!
https://linustechtips.com/topic/469960-gaming-pc-help/
Seems fine, but you may want to get a r9 390 sense it does edge out the 970 in some games.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/469960-gaming-pc-help/#findComment-6301843
looks pretty good. check out benchmarks for those games with a GTX970.
follow your topic.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/469960-gaming-pc-help/#findComment-6301846
This would be better for gaming.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£199.99 @ Amazon UK)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  (£114.96 @ Amazon UK)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  (£45.54 @ CCL Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£68.34 @ Aria PC)
Video Card: MSI Radeon R9 390 8GB Video Card  (£264.97 @ Aria PC)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£9.00 @ CCL Computers)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£72.96 @ Amazon UK)
Wireless Network Adapter: Edimax EW-7811Un 802.11b/g/n USB 2.0 Wi-Fi Adapter  (£6.24 @ Aria PC)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan  (£5.26 @ Aria PC)
Fan Controller: NZXT Sentry Mesh Fan Controller  (£19.98 @ Novatech)
Monitor: BenQ XL2411Z 144Hz 24.0" Monitor  (£206.71 @ CCL Computers)
Total: £1326.77
Generated by PCPartPicker 2015-10-19 17:20 BST+0100
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/469960-gaming-pc-help/#findComment-6301868
I would suggest R9 390 from msi or sapphire nitro, but if you want to go with Gtx 970 go woth gigabyte g1 gaming (better overclocking, performance and cooling)
Main Gaming Rig: Processor: i7 4790, RAM: Kingston HyperX CL9 16GB DDR3 1867Mhz, GPU: Gigabyte G1 Gaming GTX 970 2-way SLI, Mobo: Gigabyte Z97 Gaming 5, PSU: Corsair RM 1000W, Storage:120GB OCZ SSD, 1TB Seagate HDD,
Notebook:Ideapad wid i5 @1.6 Ghz and GT820m wid 4GB RAM
https://linustechtips.com/topic/469960-gaming-pc-help/#findComment-6301874
I though you could only do that with copies of w8 that were acquired before the updates were available.
Can't you just download Windows 10 for free when having an older Windows?
You can :P
USEFUL LINKS:
https://linustechtips.com/topic/469960-gaming-pc-help/#findComment-6301893
