Hi!
I have a problem with my pc between mobo and graphic card. I've just bought a AsRock H61M-VG4 but it doesn't recognise my GeForce GTX 550Ti and i don't know how to solve this problem. In Device Manager the Unknown Device is a Compatible System ACPI Windows.
Can anyone help me?
Thanks
https://linustechtips.com/topic/469947-problem-between-mobo-and-graphic-card/
have you tried a different PCI-E slot?
made sure the GPU has power?
tried the GPU in a different computer?
followed your thread?
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
