I have not been able to decide whether to go with two gpus or one. For example i can go with two 980s or one 980 ti, I have seen videos explaining which is better, but there are mixed answers. So heres my question. What are the benefits of have one gpu vs two, or what are the benefits of having two vs one.
https://linustechtips.com/topic/469457-is-two-better-than-one/
Biggest thing you need to know about sli, sli performance isnt at all consistaint sometimes you will see 80%+ fps increase (rare) other times a game will run worse on 2 cards (also pretty rare...but 80+% increase is more rare...)
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/469457-is-two-better-than-one/#findComment-6295695
at first I thought this was a phone thread
honestly it depends on the games you'll be playing
do they support SLI well? if so, 2 would probably be better
if not, one is the way to go
there are also other factors such as heat dissipation, because obviously with 2 cards you'll be producing more heat so you'll need to cool down those cards
also, it's louder to have two cards vs 1 (usually)
https://linustechtips.com/topic/469457-is-two-better-than-one/#findComment-6295696
I guess it be better to go with 1. Seems like two would give more problems.
https://linustechtips.com/topic/469457-is-two-better-than-one/#findComment-6295743
