Fan blow direction
Go to solution Solved by zzenigmaxzz,
you want air coming in from the front and bottom (provided its not on carpet) and out through the back and the top. you want more coming in that going out so you have positive pressure to help control dust and you want to filter your in takes
one of the things that will help you most will be a better heat sink, stock amd heat sinks are poo, spend like 25 bucks and get a hyper 212 evo and you will see a big difference in temps
I have a really crappy pc case, which holds 4 120 mm fans. The locations of these fans are 2 on the top, above the mobo, one in the back top, and one in the bottom front. I'm wondering about the best directions for the fans to be blowing, as I'm experiencing heat issues right now.
https://linustechtips.com/topic/469439-fan-blow-direction/
front and top to intake, rear to exhaust.
https://linustechtips.com/topic/469439-fan-blow-direction/#findComment-6295459
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/469439-fan-blow-direction/#findComment-6295480
1x intake front and bottom
2x exhaust back and top
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/469439-fan-blow-direction/#findComment-6295487
Alright, thanks guys. When I put the fans in, my intent was to have the top 2 and front ones in, with the back exhaust, but me, being an idiot, couldn't find the direction that the fans blew in. So now it's opposite of what everyone says should be right lol. And I will be buying a new cpu cooler now, thanks for the suggestion. Any recommendations for a good one for around $25?
https://linustechtips.com/topic/469439-fan-blow-direction/#findComment-6295520
212 evo
https://linustechtips.com/topic/469439-fan-blow-direction/#findComment-6295533
the hyper 212 lol
and look at it like this, the air will always blow towards the stickered side (atleast on every fan ive seen)
https://linustechtips.com/topic/469439-fan-blow-direction/#findComment-6295538
Agree on this.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/469439-fan-blow-direction/#findComment-6295562
