My first build primarily for gaming, wondering what experienced builders think:
 Intel Core i3-4170
Gigabyte GA-H97M-D3H Micro ATX
Kingston HyperX Fury Red 8GB (2 x 4GB)
Kingston SSDNow V300 Series 120GB
Western Digital Caviar Blue 1TB
EVGA GeForce GTX 750 Ti 2GB FTW
Corsair SPEC-01 RED
Corsair CX 430W 80+ Bronze
https://linustechtips.com/topic/469101-first-build-thoughts/
What's your budget?
I'd say, change the SSD to like 120GB Samsung 850 EVO, it performs better.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6291592
 Intel Core i3-4170
Corsair SPEC-01 RED
What's the total budget? and in such a budget oriented build I would highly recommend not getting a SSD until you have extra money down the road. I'd take the money from your SSD and put it towards a 960 or 380 as well as picking up a higher end PSU, if you do that you'll have an infinitely better time. Other than that- nice build :)
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6291593
Could not of stated this better myself.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6291616
Great minds think alike! SSD's don't have much of a place in builds under $800, I mean you'll end up putting like 3 or 4 AAA titles and your OS plus some programs on it then you'll be out of space. In budget builds all money should be focused on shear performances with luxuries like SSD's coming later on.
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6291632
SSDs are a luxury not a must :) In 5, 10, whatever amount of years we will be saying something else is a luxury not a must.
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6291665
Well I believe when a 250GB SSD is only 50$ then it's worth it in a budget build but even now at 90$ it's still out of the way.
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6291685
like the guys said, consider the SSD as a future upgrade and dump more money into a better GPU and a better PSU instead.
R9 380 and 500W+ PSU bronze rated or better that has good reviews.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6291733
thanks for the suggestion! I will definitely scratch the ssd for an upgrade in the graphics card/psu and then buy an ssd later :D
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6296538
 Intel Core i3-4170
Corsair SPEC-01 RED
That ssd just no. They might've said they've fixed it, but better safe than sorry. And what people were saying about the psu and gpu. Cut ssd, get hard drive, better psu and gpu, profit.
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6296568
Update:
No SSD
MSI Radeon R9 380
Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply
everything else the same
nice, if budget is tight, this will deliver what you need...it's a better machine than a PS4 for example.
i would try to get the i5-4460 though, as it will allow for a GPU upgrade down the road where as the core i3 will be pretty much maxed out with this GPU, listen to this video, at first they test the card with an i7...then they swap to a core i3-4130 to see what happen and then even the GTX950 which is quite weak in nvidia's line-up pulls ahead, interesting video:
The i3 is still pretty good, clocked faster than this one and will deliver playable framerates in every games...but the i5 is notieably better and will be relevant longer...unless you would plan an upgrade to say an i7-4790 or xeon E3-1231V3 and an R9 390X or Fury or something in which case i would recommend again a better pSU...but i5-4460 and R9 380 would be nicer, wait for black friday?! get deals...buy used GPU if possible? a GTX 780 should cost about the same used and is MUCH more powerful...these cards last 8 to 10 years easily even on a dusty dirty smoker machine.
EDIT: well...listening back to this video attest that something like a core i3-4130 already limit the performance of a R7 360...so maybe a better CPU would be better for you than a better CPU depending of what type of games you play...what games are you looking to render and at what screen resolution ?
Sure the i3-4170 is a little faster but still...i don't know!
Edited by i_build_nanosuits
https://linustechtips.com/topic/469101-first-build-thoughts/#findComment-6297275
