hello, im trying to find a 4GB DDR3 SDRAM stick for a hp pavallion g6 2323dx laptop. can anyone send me a cheap link to a ram stick of that specs on newegg?
product page for the laptop
http://support.hp.com/us-en/document/c03665286
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/468803-need-help-finding-laptop-ram/
is it for a replacement? if yes - any SODIMM DDR3 SDRAM "should" do.
if its to combine with the ram thats in there, their support page isnt really enough to know.
do you have any idea if i can replace the a8 4500m with an a10 5750m? the bios version is f.25 which supports richland, but could i change it out?
Rigs I've Built
well.. if only amd had something like ark.intel :/
its kinda needlessly hard to find detailed information about amd processors.
I haven't the slightest idea. Usually if it's the same socket (and the mobo supports the power draw) and the BIOS is updated to support the chip then you should be able to drop it in without a problem.
