Needing Help Understanding a Few Things
Solved by shypin,
you can go a slim 240 in the front with maybe a single 120 in top or rear
i think you can mount a reservoir quite easily on that cable management thing
maybe something like this https://shop.ekwb.com/ek-kit-l240-1
if you want to add another radiator thats gonna add about $60 i think, gpu blocks costs about $120 each, gpu backplates are about $30 each
