Operating System taking a while...
- Disable Legacy USB from your UEFI
- Disable CSM (Compatibility Support Module) in the UEFI
- Make sure your SATA cables are well connected everywhere
- Make sure that your SATA controller is set to AHCI mode
- Make sure you boot from the disk as EFI mode if you have the option to do so.
- Unplug any USB peripherals attacked to the system beside a standard keyboard and mouse.
- Remove any overclock settings you did
- Make sure that X.M.P is set to Profile 1 in your UEFI
- If your case or you have an SD card reader, remove it.
- Change your SSD/HDD SATA cable.
If that doesn't work
- Try and disable your CPU visualization features in the UEFI (if it works, and once setup, you should be able to enable it again, and have no problem)
- Check for faulty RAM. Remove all stick, and use 1 at a time (refer to the motherboard manual to know where the stick should installed)
- Use another system and a USB flash drive and get the latest BIOS/UEFI for your system, and put the downloaded file extracted in your USB flash drive (formatted as FAT32) and refer to the manual of your motherboard on how to update it.
