My friends computer will not turn on after installing new RAM
His motherboard is the Gigabyte GA-G41M-Combo
The new memory is Kingston hyper x ddr3 1333
It will not go to bios
His old momory was ddr 2
Corsair 350d, Asus Gryphon Z87, Intel i5 4670k 4.5 GHz, Corsair H100i, Corsair Vengence 16gb 1600 MHz,
AMD Radeon 260x, Corsair CX600, OCZ Vetex 450 128gb, Seagate 2 TB
https://linustechtips.com/topic/46775-help/
DDR3 and DDR2 aren't compatible, they are completely different. Are they in the right slots?
https://linustechtips.com/topic/46775-help/#findComment-618445
If no one's suggestions work, it's faulty RAM.
https://linustechtips.com/topic/46775-help/#findComment-618447
Some boards have both DDR2 and DDR3 DIMM slots.
https://linustechtips.com/topic/46775-help/#findComment-618451
On Newegg's website about the board in support of different DIMMs: 4×240pin DDR3 1333(O.C.)/1066/800 or DDR2 1066(O.C.)/800/667
https://linustechtips.com/topic/46775-help/#findComment-618467
the motherbouard that he has suports both ddr2 and ddr3
http://www.gigabyte.us/products/product-page.aspx?pid=3505#sp
 and the cpu is an intel celeron e3300
https://linustechtips.com/topic/46775-help/#findComment-618471
What is the specfic memory? Most kingston ram is 1.65v in the 1600mhz speed, but it may be the same for 1333mhz.
https://linustechtips.com/topic/46775-help/#findComment-618487
There are motherboards that support both DDR2 and DDR3 on the same board. But of course you could only use one type at a time.
Examples are his board GA-G41-Combo and mine ASRock N68C-GS FX
Try re seating the new ram on the board and what the others have suggested as well. Or test it on another PC. If that fails, faulty ram.
Good enough.
https://linustechtips.com/topic/46775-help/#findComment-618635
