Windows right click problem
Go to solution Solved by Penny5837,
try simply creating another user account. is it still there?
I'm updating right now, if that doesn't work then I'll try this next, and then re-installing.
oh god burn it with fire!
But yeah, reinstall.  I guarantee that will be much faster than trying to troubleshoot
Would refreshing fix it?
To be perfectly honest, I'm not entirely sure what that does.  I think it's close to a reinstall but I don't know.  It would be easiest and fastest to just reinstall.  That's what I would do without a second thought if I had this happen to me
Alright. Thanks
Updating fixed it.
nice. Sometimes things break, and letting the updater update can fix them. Good to know you didnt have to reinstall. I am on my fourth install.
