an icon problem
By
OSBK
in Operating Systems
Solved by GoodBytes,
Your games should not have that symbol at all. You are probably running it under compatibility mode, or you set it to run as admin.
Right-click on the icon, select Properties, go to the "Compatibility" tab, and uncheck all boxes.
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
