Hello, I have been looking into cpu coolers, and I was wondering if I should purchase a water cooler, or just stick with a air cooler and save some money. I will only be doing a mild overclock, and Im hoping for a 4.0 ghz or a 4.2 ghz overclock. If I should choose air cooling, what cooler should I use? My specs are in my sig.
Intel i5 4690k | NZXT Kraken x61 | MSI z97 Gaming 5 | MSI GTX 970 EVGA Supernova G2 750 G-Skill Ripjaws 16GB 2133mhz [2x8] | Western Digital Caviar Blue 1TB HDD Samsung 850 EVO Series 250GB SSD NZXT H440 [black and Red]
Saving for a Dream rig :)
https://linustechtips.com/topic/466562-cooling-options/
If you don't mind noise then an air cooler is fine. A 212 evo or bequiet pure rock are both great and will keep your cpu cool.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/466562-cooling-options/#findComment-6260731
Where are you shopping/located?
https://linustechtips.com/topic/466562-cooling-options/#findComment-6264196
I thought most AIOs are noisier since you have pump noise AND fan noise where air coolers only have fan noise.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/466562-cooling-options/#findComment-6265063
I'm assuming that he'll get a cheap cooler that would be louder under load due to lower cooling capacity versus an expensive AIO.
https://linustechtips.com/topic/466562-cooling-options/#findComment-6267123
By budget is a max of 150, but I would like to stay at 100 or under.
https://linustechtips.com/topic/466562-cooling-options/#findComment-6267364
If we would be talking about AIO and air cooler that are same range in terms of performance, AIO
USD? be Quiet! Dark Rock would be optimal in air coolers. Its midrange in terms of price and performance. It will be enough for general OC and look good in your case.
https://linustechtips.com/topic/466562-cooling-options/#findComment-6267525
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/466562-cooling-options/#findComment-6267720
