Hi guys,
I'm doing my first ever build and was wondering if you guys could check my build and see if there is any changes I could make. My original budget was £1000 but i've kinda gone over :/
Can somebody please help me lower it if possible. Everything apart from the ssd is purchased from Amazon (No idea if that helps). Oh and i'm based in the UK.
Note: I can't use any old pc parts as i'm giving it to a family member.
Build
Motherboard Asus Z87-Plus @ £130.35
CPU Intel Core i5 4670K  @ £184.24
CPU Cooler Cooler Master Hyper 212 EVO @ £23.62
RAM Kingston Technology XMP Beast Series 8GB (2x4gb) 1600MHz @ £55.97
GPU Asus GTX 670 DirectCU II OC 2GB @ £195.20
SSD Samsung 840 Evo Basic 120GB  @ £86.54
Mechanical Seagate Barracuda 3.5 inch 2TB 7200 RPM 64MB 6GB/S @ £58.17
PSU Corsair Builder Series CXM 600W Modular 80 PLUS Bronze @ £58.86
Case Cooler Master CM Storm Scout 2 @ £80.75
Optical Drive SAMSUNG SH-224DB @ £13.76
Monitor LG 23EA63V 23 inch Widescreen LED IPS Monitor (x2) @ £114.94
Total Cost   £1,117.34
Thank you!  :)
CPU: Intel Core i5 4670K | CPU Cooler: Coolermaster Hyper 212 Evo | Motherboard: Asus Z87 PRO | Ram: Corsair Vengence 8GB DDR3 | Graphics Card: Asus GTX 670 Direct CU II OC | SSD128GB Samsung 840 Evo  | HDD: 2TB Seagate Barracuda
Case: CM Storm Scout 2 | Monitor: 2x LG 22EA53VQ IPS
OS: Windows 8 Professional 64 Bit
https://linustechtips.com/topic/46613-my-first-build-please-help/
You did well. Nice case btw ;)
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616102
Thanks guys! Are there any motherboards you can recommend that would be cheaper but still have similar features?
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616113
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616129
Good overall build but go with 1600mhz ram.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616151
Nice build you have done your research. I don't see many places to drop price other than the motherboard a Asus Pro isn't necessary for an average user.
Edit: As Volbet said and I missed, just get 1600mhz RAM.
Would this be better?
http://www.amazon.co.uk/Z87-Plus-Motherboard-Intelligent-Processors-Optimization/dp/B00CXK57FS/ref=sr_1_1?ie=UTF8&qid=1376666364&sr=8-1&keywords=z87+plus
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616165
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616173
That works perfectly if you want to stick with the gold color scheme.
Thanks, the main reason I wanted to go with Asus is the software.
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616191
Optical Drive question:
what is the difference between OEM and Non OEM optical drives?
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616263
OEM drives doesn't include SATA data cables and SATA power cables
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616324
So should i not consider these? Would those accessories be likely to come with other parts of my build?
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616356
SATA power comes in you PSU and SATA data cables comes with your motherboard. There is no need to purchase extra cables
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616372
@Volbet
Would you say I should get more case fans or would the fans in the current case be sufficient?
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616769
@Volbet
As far as I can tell they give you plenty of fans with the case. You can always build the system and see what you think and then maybe buy more fans if you feel you need them.
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-616784
Here you go: http://uk.pcpartpicker.com/p/1sGTg
I would recommend getting a matx build instead if you're not stuck on the case. Matx would be smaller, easier to transport, cheaper, and does everything you need.
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-617309
@WoodenMarker
Would a 600w power supply be sufficient for my current build and if i wanted to add hard drives later on?
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-623030
You could easily add 6 more harddrives and not have to worry 600w is plenty.
Edit: change your GPU from a 670 to a 770 ;) There's no reason to go last gen if you don't have to.
When would I ever need to change the psu?
Ah if only but a 770 is way over my budget :(.
https://linustechtips.com/topic/46613-my-first-build-please-help/#findComment-623079
