What PSU would you recommend for a system that has an I7 6700k and a 390x? Best if it has good quality (Japan capacitors instead of Chinese) and it doesn't make a lot of noise.
Because i bought a Seasonic 1050w gold thinking the hybrid fan mode was going to be silent and in reality i'ts horrendous (its even louder than the GPU while gaming), it kicks to full fan speed when its absolutely not needed, like when browsing, and it also does that randomly while gaming. And "normal" mode is just the fan at 100% all the time.
So, yea, i dont want to pick the wrong one this time xD.
Also, price is not a problem, and i dont mind going overkill to have a more silent psu.
And, well, in some years i will want to change the GPU without changing the PSU, so i also want a bit of headroom for updates and overclocking.
The full specs are this, just in case:
Asus Maximus Hero VIII
I7 6700k
Sapphire Tri-X AMD 390X
2x8 Gb G-skill 3000Mhz CL15
Corsair H110i GTX (it has stock fans but in a couple of days im going to replace them with a pair of NF-A14 Noctuas)
Corsair Obsidian 750D (might replace the fans in the future)
2 Seagate 3TB
2 Samsung 840 evo 250Gb
Seasonic 1050W Gold
https://linustechtips.com/topic/465974-help-picking-a-quality-quiet-psu/
Higher end Corsair PSUs have zero rpm modes and my RM hasn't had to use the fan yet. Be Quiet should Have some quiet ones too. If you really want silence, look into fanless power supplies.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
RM Series has 0RPM Mode, you wont hear much from a PSU Fan tho
that thing is outdated and not accurate
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
RMA the SeaSonic PSU. My SeaSonic S12G is silent and you may have received a defective PSU.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
I have the rm750 and it is dead silent, even compared to the evga g2 750w i owned before.
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
  • 3 weeks later...
Ended picking up the Corsair RM1000i.
Working like a charm and dead silent. The only downside is that the cables were a bit hard to route in the case because they are a bit short and have some non flex zones that have some componentes inside, but when all is setup i encountered no problems.
Thanks for the help guys :).
