Best fan for a radiator in pull
Metro
Hello
What is better Noctua NF F12 or EK Vardar for the best performance and being quiet
It will go on a EK Predator 360mm in pull
Price is not an issue, same with colour
Thanks
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
Hello
Thanks
I would go for a Corsair SP 120 mm  / 140mm, i think that they are less expensive than Noctuas,
But if you are ready for the extra budget, i would pick Noctua ^^
The NF-F12 isn't optimized for pull but can get quieter than the Vardar. The NF-F12 should be better in push but I'm not sure when it comes to pull.
Hello
Thanks
EK!
just because its a slovenian company!!
        Sample Text ( ͡° ͜ʖ ͡°)
Does anyone have the EK Vardar fan on a radiator here
