CPU TEMPS HIGH, FAN NOT RUNNING.
Well, first off, 61 degrees isn't that hot. 80 degrees is hot. Like everyone else is saying, look at the fan itself. If it's truly not spinning, the first thing I'd do is unplug my computer, get to a static-free environment, open my computer, unplug the fan from its header, then plug it back in. If the problem persists, then you should contact your motherboard's manufacturer.
Featured Topics
BigChungus1009 ·
Posted in Troubleshooting0 -
Scorpiopt ·
4
ThankGodItsFriday ·
Posted in Programs, Apps and Websites2 -
frostymelts ·
Posted in Troubleshooting4 -
3
RevGAM ·
Posted in Custom Loop and Exotic Cooling8 -
JakubR88 ·
Posted in Power Supplies9 -
2
3
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
