Error messages? What happens when you try to install?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/465465-install-problems/#findComment-6246167
Im having trouble installing anything to my pc. such as itunes, avg, bluestacks and more. really really annoying. there is always an error of failed installation.  any suggestions
thanks
are you admin
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/465465-install-problems/#findComment-6246170
what is the error...
https://linustechtips.com/topic/465465-install-problems/#findComment-6246198
sry your right. when installing windows essentials now i found out. but i rebooted and something is still installing. any ideas??
Thats weird. I would try opening up the task manager and ending things that look like an installer.
https://linustechtips.com/topic/465465-install-problems/#findComment-6246463
