First Build - After Advice
Go to solution Solved by jimakos234,
Solid build. Just avoid the NEX series, get EVGA G2/GS/PS/P2 series and you are good to go
Hello World,
I tried once to make a rig for my PC and i failed, so i made another one, i need some advice on what should i change or improve, thanks in advance. :)
PCPartPicker part list: http://pcpartpicker.com/p/6KqdRB
Price breakdown by merchant: http://pcpartpicker.com/p/6KqdRB/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($74.99 @ NCIX US)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($129.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($78.89 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.33 @ OutletPC)
Video Card: EVGA GeForce GTX 980 4GB Classified ACX 2.0 Video Card  ($532.98 @ Newegg)
Case: NZXT H440 Designed by Razer™ ATX Mid Tower Case  ($128.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($64.99 @ NCIX US)
Total: $1378.04
Generated by PCPartPicker 2015-10-10 16:31 EDT-0400
I might be able to expand my budget up to $1500 but the cheaper the better :3
https://linustechtips.com/topic/464917-first-build-after-advice/
if youre gonna go that high for a 980 classified you might as well get a 980 ti and as has been said already stay away from the nex series psus, you want the g2 evgas not the g1s
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/464917-first-build-after-advice/#findComment-6239492
Hello World,
Total: $1378.04
Obligatory "Follow your own topics"
Also get the EVGA GS/G2/B2 instead of the NEX.
https://linustechtips.com/topic/464917-first-build-after-advice/#findComment-6239493
Ok, i just changed the PSU to a EVGA 750W 80+ Gold (G2)
Try to Incorporate the Sexy as Fuck Parvum Case.
Nad, the H440 Razer is Sexy af :3
https://linustechtips.com/topic/464917-first-build-after-advice/#findComment-6239526
The EVGA GTX 980 Classified is $532.98 and an EVGA GTX 980Ti SC is $664.98, that's a huge difference in price so i'll go for the 980 :)
https://linustechtips.com/topic/464917-first-build-after-advice/#findComment-6239559
