best cooler for 60$
Go to solution Solved by WoodenMarker,
A Kotetsu should be plenty: http://www.mlacom.si/scythe-kotetsu-scktt-1000
If you want to spend more for a better cooler, the Ninja 4 is great alternative http://www.mlacom.si/scythe-ninja-4-scnj-4000
What kind of dollars are you using and what are you cooling?
https://linustechtips.com/topic/464266-best-cooler-for-60/#findComment-6235483
I'm using €(60 is my limit or maybe max 70)
I'm cooling 4690k 1.15V
Where are you shopping/located? Are you pushing for higher clocks?
https://linustechtips.com/topic/464266-best-cooler-for-60/#findComment-6235958
Well I'm from Slovenia and there I can get almost every cooler.
I'm not pushing it higher than 1.15v because I can achieve stable 4.6 GHz
How about this 1?
ENERMAX Liqmax II 120
There should be quieter and/or cheaper options available.
Can you link us to where you're shopping?
https://linustechtips.com/topic/464266-best-cooler-for-60/#findComment-6236040
https://linustechtips.com/topic/464266-best-cooler-for-60/#findComment-6236104
