if you're slow, then you could get away using a dremel to slowly cut a square/any shape in it. then get some clear plastics and cut it to size, or get a glass pane cut to the right dimensions.
There are better options, but im far too burned out to think of any besides that.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/464235-diy-case-window/#findComment-6231100
