Problem with backplate
Go to solution Solved by Enderman,
you dont put a backplate on X99
Hey guys,
I've been trying to put the cooler backplate on my mobo, but I'm having a problem; 4 black "things" are covering the screw holes.
Sorry for bad pic, was hurried and phone ran out of battery. Specs are https://pcpartpicker.com/p/WhyK99 -- what should I do with the backplate? The mobo is sabertooth x99
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
https://linustechtips.com/topic/462732-problem-with-backplate/
https://linustechtips.com/topic/462732-problem-with-backplate/#findComment-6210096
omg so stupid thanks !!
Everyday build:
Weekend build:
https://linustechtips.com/topic/462732-problem-with-backplate/#findComment-6210108
