Posted October 6, 2015 Hello everyone.. I am a new user of this site. I have a desktop with the following configuration. CPU: Intel core i7 5820k Motherboard: MSI X99s GAMING 7 GPU: MSI GTX 960 gaming CPU cooler : Thermaltake water 3.0 AIO single radiator cooler PSU: Thermaltake Litepower 530W I don't overclock my machine.. I am not sure that my PSU is enough. urgently need some advice on PSU recommendation..Thanks in advance Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 6, 2015 Hello everyone.. I am a new user of this site. I have a desktop with the following configuration. CPU: Intel core i7 5820k Motherboard: MSI X99s GAMING 7 GPU: MSI GTX 960 gaming CPU cooler : Thermaltake water 3.0 AIO single radiator cooler PSU: Thermaltake Litepower 530W I don't overclock my machine.. I am not sure that my PSU is enough. urgently need some advice on PSU recommendation.. Thanks in advance http://pcpartpicker.com/part/evga-power-supply-220gs0650v1 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 6, 2015 http://pcpartpicker.com/part/evga-power-supply-220gs0650v1 This except get the 550W version if it's cheaper. |PSU Tier List /80 Plus Efficiency| PSU stuff if you need it. My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon || Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 6, 2015 EVGA G2 550w EVGA GS 550wXFX Core Edition 550w Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 6, 2015 Your psu is easily enough. However, while of decent quality, this is an entry level psu compared to your high end pc. That is why people recommend other psus with similar wattage. If its not too loud or bother you otherwise you can just leave it in. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 6, 2015 Author Currently I am using Thermaltake Water 3.0 Performer cpu cooler with this 5820k cpu...Is is enough for cooling this cpu..I have a plan to upgrade it . Can i go for COOLER MASTER V8 GTS .. THANKS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 6, 2015 Author Your psu is easily enough. However, while of decent quality, this is an entry level psu compared to your high end pc. That is why people recommend other psus with similar wattage. If its not too loud or bother you otherwise you can just leave Thank you brother for your nice suggestion Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
