PC Upgrade Help
Solved by Raccatography,
good point sir, but what you are saying by that (just to clarify) is i should upgrade both the psu and the gpu at the same time or just the gpu
clarifying your clarification: Just change the GPU entirely instead of getting another GTX 770 for SLI. Upgrade the PSU as well. If budget allows it, get a new PSU ![]()
ps I just realized it now. you're gaming at 1080p. You'll be able to do play games on max with a R9 390. The 980 Ti to drive your monitor for games is just overkill, haha. But then bragging rights
