So i installed razer synapse and started to mess around with things like the led on the keyboard and the macro keys, then it crashed and restarted and now its making my windows play up, the start key has a 5 second delay and when i does register its like some one is spamming the windows key. it will make the mouse i have witch in not even a razer mouse repetitive click (i can hover my mouse over a folder and it will open it)help
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/462326-razer-synapse-help/
So i installed razer synapse and started to mess around with things like the led on the keyboard and the macro keys then it crashed and restarted and now its making my windows play up the start key has a 5 second delay and when i does register its like some one is spamming the windows key and it will the mouse i have witch in not even a razer mouse will repetitive click (i can hover my mouse over a folder and it will open it)help
can you edit in some punctuation? I'm getting lost which one is happening and which one isn't
CPU: i7-5930k  CPU Cooler: Noctua U14-S GPU: Asus GTX 970 Strix Memory:  32GB G.Skill Ripjaws 4 2133 MHz Mobo:  Asus X99 Deluxe PSU: EVGA 1200 P2 Case: NZXT H440 B/W Case Fans: (3x) NF-F12, (3x) AF120 QE, (1x) AF140 QE Storage: Samsung EVO 250GB (OS/Programs), Samsung 850 500GB (Games), 2x WD Blue 1TB 2x WD Green 2TB.
https://linustechtips.com/topic/462326-razer-synapse-help/#findComment-6204698
Welcome to Razer's crap software...
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/462326-razer-synapse-help/#findComment-6204821
Razer software is the worst software i ever saw!!!
I have the Naga 2014 and i regret every single buying it!!!!
Razer sinapse is to spit on the floor!!!
One day it did it to me too, every think collapsed, had to unistall... reinstall the software couple of times!!!
And if you dont have a conection you just cant export or inport any profile!!!
Simply inadmissible!!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/462326-razer-synapse-help/#findComment-6204914
