I'll start off by saying, I'm no crazy audiophile, but I do care about sound. I've been looking into making my own cables for my TMA-1s as a DIY project (connecting to a Fiio E10). I've been seeing on head-fi people are buying solid (and expensive) pure silver wiring. Is this necessary? Would regular stranded pure (~99%) copper wiring (and to what gauge) provide any noticeable difference in SQ from stock cables?
Thanks!
Rig: Lian Li PC-V353 i5 2500K, GA-Z68MA-D2H, EVGA GTX 650, CM Gemiin S524, Corsair TX650M, Crucial M4 128GB, Seagate 1TB Barracuda, Fiio E10
https://linustechtips.com/topic/46135-custom-headphone-cables/
Cables do not change sound unless their resistance is too high (ie they aren't thick enough for the distance they're traveling).
Expensive cables are pure snake oil.
https://linustechtips.com/topic/46135-custom-headphone-cables/#findComment-608414
not worth it if you're changing it for sound.
only do it if your current cable is broken, or you want to change the termination, length, stiffness, or looks.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/46135-custom-headphone-cables/#findComment-608590
4. Cables - They don't matter unless they have bad connectors or they break inside. Digital matters even less as long as it's a properly built cable. See: http://www.theaudioc...Critic_26_r.pdf (page 5)
from the first FAQ answer
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/46135-custom-headphone-cables/#findComment-608919
I spent $300/metre on pure OFC silver monster cables and not only did my Microsoft headset sound better but my sex life improved too. :wacko:
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/46135-custom-headphone-cables/#findComment-608938
Ok, thanks for the help. I needed a new cable for portability (carrying around a 6+ foot cable when its only connected to something in your pocket is useless for me). Just wondering why people were dumping money. Maybe unicorn hair would work better?  :blink:
https://linustechtips.com/topic/46135-custom-headphone-cables/#findComment-611021
Makes great pillows!
https://linustechtips.com/topic/46135-custom-headphone-cables/#findComment-611685
