a 360 and a 240
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-607323
a 360 and a 240
i agree with this but the more rad space the lower ur fans can run to acheve the same temp so the more the better
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-607332
ok now say i do 50 mm rads
2 240
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-607391
so i want to custom water cool my i7 4770k oc to 4.5 and my gtx 780, how much rad would i need?
i a looking at 30 fins per inch radiators that are 25mm thick
if you want quiet fans and low temps, you need to increase the radiator thickness and/or
decrease FPI usually minimum to hold less than 1200rpom fan speeds and tolerable
temps a 360x 60 or 2x 240x 60 radiators.
better.. how sensitive are you to constant fan noise?
what case is this all fitting in?
airdeano
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-608035
I'm running an I5 2500k (4.5 OC) and a 780 (1253mhz OC) cooled by a 420mm,  60mm thick rad and get great temps. 780 never goes above 45
your CPU will put out some more heat obviously but I figured you could use a reference
that's great for GPU and expected.. but the CPU is what is critical for temperatures.
what are you seeing for CPU temps and what voltage?
airdeano
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-614204
A 360 and at least 30mm thick is all you need
^this
to OP
Honestly this is really all you "need". Since you posted you don't care about noise you can prolly even get away with a 240 (45ish mm and thicker) and high rpm fans. From there you can add more rads and turn down fan speeds...
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-647180
The normal minimum rule for water cooling is one 120mm wide by 25mm deap rad per item being water-cooled. Then plus one rad. So if your water-cooling a cpu and gpu you would want a 360mm rad. If you wanted really good temperatures and near silent running fans increase the thickens of a rads or add and extra one if you have the room.
I hope this is clear
My watercooling set up is as follows: I have one 240mm x 25mm all copper rad and one 240mm x 86mm rad. All have corsair sp120 quite editions with stepdowns to.
And this is cooling my CPU and GPU
Nice and quite. any more questions please ask.
Asus Maximus VI Hero , i5 4670k , 8gb Corsair vengeance ddr3, Asus HD 7970 matrix platinum, Corsair AX860, Ocz agility 3 120gb ssd, 1tb wd green hdd, custom water loop. All in an Antec p280
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-648361
Not sure what your talking about. A 240mm rad will not give very satisfying results because a 360 has more surface area even if the 240 is 45mm thick. I don't think I ever posted "I Don't care about noise" but if I did that has changed. If OP can fit a 260 then he should fit a 360. If not I recommend he adds a 120mm / 140mm to the rear of the case
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-651179
I clarified my original post.  I was quoted you as to confirm what you said, my actual comment was directed at the OP.
what I meant by the 240 comment is that it would be enough to run the system.  Of course a 360 or more would be better.  But as far as bare minimum you can easily run a cpu and gpu on a thickish 240 as long as you have some pretty good fans on it.
https://linustechtips.com/topic/46081-how-much-rad-do-i-need/#findComment-651294
